zone valves
Joe Mattiello_2
Member Posts: 94
try the Taco zonvalve. For your reference I attached the insturction
Joe Mattiello
Technical Support Technician
Tel. 401-942-8000 X 484
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
joemat@taco-hvac.com
Joe Mattiello
Fax. 401-942-2360
1160 Cranston St
Cranston, RI 02920
zone valve
customer has erie zone valve need to replaced since i have to empty system,no isolation valves,is their one better then the other ,Ilike taco and erie .any suggestions ,he has four valves0 -
I like the erie also. Can't you just change thew motor? Then there is no need to drain system.0 -
THE MECHANISM IN VALVE IS HANGING UP .I TRIED TO MANUALLY OPEN AND IT DOES NOT OPEN ALL GEARS APPEAR TO LOOK GOOD THIS IS THE OLD STYLE ,iWISH THE NEW STYLE WAS THEIR .tHANKS0
- 87.1K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
