Wall Stacks
David Sutton_6
Member Posts: 1,079
Try using oval pipe instead of rectangle , its less cutting of the sacred lumber..;-)
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=386&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Hi Guys,
I have a customer that would like me to install some AC in addition to Radiant Floor heat. I am an experienced tin knocker but I have never done an estimation for wall stacks as we are mainly a Radiant Floor Heating contractor...
What do you guys usually figure for man hours?0 -
Your job...
Not sure exactly what type of structure you have, but can you consolidate by putting A/C , 1 up and 1 down? Would eliminate stack work.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
