Boilermate Single Button WH7L Instruction Manual ?
kevin coppinger_4
Member Posts: 2,124
in RI.....401.884.6300
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Question on Boilermate WHL7
Hi, I have this model with the single button digital control and can not seem to locate a manual online, it came with a book but describes the multibutton control panel which doesnt match what I have. Can someone give me the lowdown, I found that if I hold it that seems to set the desired temp. I pressed it 3 times and it goes to a 00 and I am not sure what that means. Also I have a spare temp sensor that was next to the unit, I dont know if they include this but wondered if there is a way to check to see if this is a good part and worth keeping. Thank you
Chris0
- 50 Industry Classes
