Digital T-Stats with fan cycle options?
Luke Lefever_3
Member Posts: 38
Check out a thermostat from Climatouch. We get ours from Jackson Systems, Indianapolis. Touch screen, inexpensive and easily customizable for all kinds of things. Including fan cycles.
Looking for t-stats with fan options
Carol, I have only found 1 stat that has this capability and that is the Invensys t-stat by, I believe Rob Shaw. It allows me to cycle the fan at timed intervals during the hour (which is adjustable) thru out the day. I like it because it moves the air to better even out the house. Do you know of anything other t-stat than the Invensys that does this?
Thanks Mike T.0 -
The Honeywell touch screen stat--TH8110 (single stage) and TH8320 (2-stage)--has a fan feature called "circulate." When you select it, the stat brings on the blower at least 5 minutes each half hour if there hasn't already been that amount of blower time through normal heating or AC cycling. It's easier than picking the times yourself.0 -
www.braeburnonline.com
Any of the Premier series have a fan recirc mode. Models 3000, 5000, 5050, 5200.0 -
Thanks All
Nice to know there is other manufacturers that offer this option.
Mike T. :-)0
- 120 Geothermal
- 396 Solar
