Temp Manifold Ideas
Cosmo_3
Cosmo_3 Member Posts: 845
Cosmo Valavanis
  • Mike C_3
    Mike C_3 Member Posts: 62
    Temp Manifold Ideas
    Hello I am looking for some ideas for manifolds on a S.O.G. setup. Right now we use conduit 90's and a piece of unistrut with rigid clamps and seems to work ok. Just looking for the next best thing.
    PICS WOULD BE AWESOME. If you want to send them directly
    mjcromp@msn.com
    Thanks in advance!!
  • Cosmo_3
    temp manifold mounting
    I just use rebar I find laying around the job anyway (re-FREE!) or I always have some in the truck when I can't find any.
    I simply drill pilot holes in the rebar and use self tapping screws to mount the Uponor (wirsbo) truflow manifold up on. When the walls are roughed in I simply cut off the rebar using a bolt cutter and mount the manifold onto the wall.
    Pic included
    Cosmo Valavanis
