Temp Manifold Ideas
Cosmo_3
Member Posts: 845
Cosmo Valavanis
Temp Manifold Ideas
Hello I am looking for some ideas for manifolds on a S.O.G. setup. Right now we use conduit 90's and a piece of unistrut with rigid clamps and seems to work ok. Just looking for the next best thing.
PICS WOULD BE AWESOME. If you want to send them directly
mjcromp@msn.com
Thanks in advance!!0 -
temp manifold mounting
I just use rebar I find laying around the job anyway (re-FREE!) or I always have some in the truck when I can't find any.
I simply drill pilot holes in the rebar and use self tapping screws to mount the Uponor (wirsbo) truflow manifold up on. When the walls are roughed in I simply cut off the rebar using a bolt cutter and mount the manifold onto the wall.
Pic included
Cosmo Valavanis0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
