sunrad radiators and baseboard heat
Mitch_6
Member Posts: 549
Normally you cannot mix and match since the Cast Iron takes longer to heat up and longer to cool down than copper baseboard.
However I have seen the mix work well if all the radiation is in the same room as the one zone.
Mitch S.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=388&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Mitch S.
can sunrad radiators be on the same heating zone as copper baseboard heat?
careful....
Dependings on the situtation, I've some works and most don't work , esp with the new addition built to homes.0
- 50 Industry Classes
