Stainless steel 316L
S Ebels
S Ebels Member Posts: 2,322
Never had the occasion or need to use anything other than Viessmann's concentric venting. Using stainless is generally done if vent lengths exceed what the concentric can handle. You lose the balanced flue feature if you go with a single pipe vent.
  • Couderay
    Couderay Member Posts: 314
    316L/pvc
    Can 316L stainless pipe be used in place of pvc for venting on a condensing boiler.
  • Ted_5
    Ted_5 Member Posts: 272
    Better choice
    Yes, it can. It is an approved boiler venting material.
    Ted
  • Brad White_167
    Brad White_167 Member Posts: 12
    Yes, but
    why would you want to? You must have some stock you need to use up! Stuff is not cheap but if you have it or can afford it, heck, why not?
    316L has lower carbon than normal 316 and is the choice for many condensing boiler heat exchangers so I cannot see why it would not work for venting.
    Viessmann uses a 316T (titanium) alloy which only they have.
    Personally I think AL29-4C looks nicer and you can shave looking at it.
    EDIT: The other points below are very well taken- my assumption is that of a choice of materials it is sanctioned by the manufacturer and manufactured as a system for the purpose.
  • Guy_6
    Guy_6 Member Posts: 450
    can or should
    Be careful-even though a material may function well, it will not release you from liability should anything happen. The safe bet is to either use what is specified in the manual or get written consent from the manufacturer.
  • S Ebels
    Back up a step
    What prompts your question in the first place?
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Other than Viessman,
    All German manufacturers specify stainless flue piping for their units in Europe.(I believe it's the law)
    Viessman uses a similar concentric vent like the ones we get here, but I'm not sure of the material.
    Personally, I'd like to have the option of using something other than PVC for vents. I feel it "cheapens" the look of an otherwise fine and beautiful appliance. I'd use it if the customer wouldn't mind paying for it. Nuff said? Chris
  • JimH
    JimH Member Posts: 89
    > the law)
    > of the material.
    > Nuff said? Chris
    I'm considering a vito install right now, and I'll definitely be asking what
    the cost delta is for stainless exhaust. PVC is extremely toxic to manufacture,
    not recyclable, and ougasses hydrochloric acid when it burns. I found it note-
    worthy that the plastic venting material Viessmann sells in the US is PP.
    Has anybody seen a vito install in the US with SS flue?
    JimH
  • JimH
    JimH
  • JimH
    oh....
    I thought the euro installs might have concentric stainlesss.
  • Perry_3
    Perry_3 Member Posts: 498
    The ballanced flue feature of the concentric vent is..
    really not that necessary from an engineering design standpoint.
    However, for several reasons the Vitodens concentric vent is the way to go IF you are going to use outdoor air for boiler air supply in a "sealed" combustion unit.
    If you are OK with using indoor air for the boiler air supply; Viessmann sells sevearal adapter kits to the common US suppliers of SS exhaust vents. The fact that the inlet air pressure drop and the exhaust vent pressure drops are not matched is not an issue.
    Under no condition am I aware where Viessmann approves the use of PVC for exhaust venting for the Vitodens.
    I do note that the Vitodens concentric venting is almost certainly cheaper than using a SS exhuast system.
    It is also my understanding that we are using the same concentric venting system that is used in Europe. All the parts are in metric lengths (but ft conversions are supplied) - and I did not check the diameters; but I'll bet that they are really metric as well.
    By the way, the Vitodens is a great boiler. Enjoy it.
    An example of what the Vitodens Concentric venting system looks like is below (this only shows the start of the vent run; about 8 ft horizonatal, 2 ft up in a 1st floor closet, then 2 ft out the house wall well above the snow line).
    Note the gallon jug under the sink does not fill up. It is a deflector for the laundry drains. When I insulated the wall and studed it I moved the laundry sink out about 8" from where it used to be and the sink drain no longer lines up with the floor basin. Something to fix in the future.
    I also know that I am pumping "to" the LLH and not away from it. A lessor issue than others I had to get right with the installation (I was not going to win them all - so I picked the issues I fought for).
    Perry
  • justme_2
    justme_2 Member Posts: 14
    Vitodens venting
    Consult Viessmann, they have the Vitodens approved for many venting configurations.
  • Couderay
    Why the question
    Yes I do have 316L in 3" and 4" and after reading a thread on PVC from awhile ago, I thought that maybe I would convert my vent to stainless. The stainless I have is schedule 10. Boiler is a 140M munchkin
  • JimH
    Thanks for the photo, Perry! I really enjoyed reading your installation story,
    and I was wondering what it looked like! It shows what an involved HO, who's
    willing to dig deep into the technical documents can accomplish...
    Just curious, when the iron soil pipe is up for replacement, will you insist on
    iron with caulked joints, or go with PVC?
    -JIm H
  • Ted_5
    Jim
    If you are with in the vent length requirements of the Viessmann venting, then use the pipe in a pipe venting. We have used SS a few times on Vitodens, but that is only because we needed to go thru the roof and had the exceed the maximum length of the concentric pipe. If you use SS, then the boiler is no longer sealed combustion. At that point it is room air dependent. The only way Viessmann allows SS venting is going thru the roof, side wall is not an option.
    Ted
