Ground-source heat pump
Josh_10
Member Posts: 786
I personally am really happy with the HSW series water to water heat pumps by Heat Controller, Inc. Their web site is www.heatcontroller.com
Ground Source Heat Pump
I am looking for info on sizing and a mfgr of heat pumps for use in a radiant floor system. Any suggestions?0 -
Heat Pump.
Try Professor Silberstein and his ChillHead's in his HVACR section "On The Wall" .Scroll way down![Same Wall}[Same People}Don't move someone will be with you shortly.0
- 167 Indoor-Air Quality
