PRESSURE ENTHALPY WITHOUT TEARS
Craig R Bergman
Member Posts: 100
you be in the Iowa area? I'm located in Cedar Rapids and would love to attend your seminar.
Bergy
Bergy
Pressure Enthalpy Hits the Road Again
My (relatively) new seminar "Pressure Enthalpy without Tears" (PEWOT) is hitting the road.
Next stop on the train is Morgantown, PA, which is located just south of Reading. It's also (pretty much) the midpoint between Philadelphia and Harrisburg. PEWOT will be there on June 25, 2006.
In July (on the 19th) we'll be in scorching Orlando, FL.
In August (on the 10th) we'll be back on Long Island at the Plainview Holiday Inn where this whole thing started.
Also in August (on the 16th) we'll be in Boston Mass.
Check out the details and hope to see you there!0 -
NO TEARS?
DEAR CHILLHEADS;I took the Professors class, I'm glad I did . Once you realize the value of all that P/E stuff,then you now have one more "tool" in your toolbox to use to be the "one" who figured out what was wrong with the system!
Learn em' good Professor!0 -
Maybe
Maybe we can fit it in when I hit Chicago and Michigan in January or so.
I'll put your request on the map.
- 123 Chimneys & Flues
