Baxi HT w/ Indirect
Bob Sweet
Member Posts: 540
Located in the mountains of the southwest. Took a little time dialing in the Baxi with the combustion analyzer, but nothing to terribly bad.
Wiring's not complete
but it's up and running, this is a retrofit replacing 75 gal water heater and 175000 btu input C.I. boiler.The Baxi is 126000 btu input, indirect is 60 gal. House is 5000 sq/ft sitting at 7200 ft above sea level.
The most impressive thing about the Baxi is the QAA 73 controller made by Siemens, it's one smart son of a gun.0 -
Nice job
Bob, where are you located ? I ask because you put 7200 ft above sea level. Boy is that up there. Must have been setting up the valve.0
