A new style of heat transfer plate
Heh, i guess if your plate can't hold the pipe tightly on its own, you'd need to do something like this, eh?
  • Tim Doran
    Tim Doran Member Posts: 208
    Saw Designs
    I saw designs for this a long time ago and had heard that it was comming. I suspect that having only one path to the base plate creates a choke point and limits transfer as compared to plates with two paths. It just seems logical. It may prove to be insignificant or non existant but I'll have to run some FEA models to see. Maybe you can get the thermal camera out and run a little test?
    Tim D.
  • bobbyg_2
    bobbyg_2 Member Posts: 139
    Has anyone seen the "tube eventually walk out" of the extruded aluminum panels?
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    I got on a mailing list
    From a close by out-of-state supplier and they had these plates listed. They look like Dales plates, only side hooked tubing instead of bottom hooked.
    Jeff
  • Ron Huber
    Ron Huber Member Posts: 121
    but what about the palm nailer
    Seems like the only way you could get the tube in the groove would be to snap it in with your thumb and fingers. Forget that, any Solaroll vets out there with arthritic thumbs like mine?
