sequencer wiring problems
Try the Find a Proffesional link on this site, and if that doesn't work, call th emanufacturer and see if they can give you alocal dealer.
Do it wrong and someone could die.
ME
  • Azrael
    Azrael Member Posts: 1
    I have a coleman electric furnace (modle #6806A722), the elements and blower were staying on and I was told that it was the sequencer. baught replacement sequencer (honeywell #R8330D) for my furnace model, but it is nothing like the one that I pulled. I need Help with wiring, please.
    thank you,
    Az
  • Ken D.
    Ken D. Member Posts: 836
    Sequencer
    Two of the terminals are the heater coil. The others should be your switches. Check the wiring diagram for the new sequencer to determine your connections. Compare to the old diagram.
