split ac system
Eugene Silberstein 3
Member Posts: 1,380
The amperage of the system will undoubtedly be different than that of the heating system, so a dedicated line would be in order.
As far as the estimate goes, we do not discuss $$ here as we cannot see the job and cannot possibly factor in all of the variables present as every job is different.
Best of luck with the system.
split ac system
Gene you advised on the Friedrich split ac system. What is a fair estimate for a 12m to 18m unit . I was quoted $3700 for a 12.5m unit. Does it need a single home run circuit or could I splice it into my dedicated boiler circuit since it is only used during the heating season>? Thanks JIM0
