boiler choice
jack z_2
jack z_2 Member Posts: 15
My sister is building a house in the country. Natural gas is not available. The house will be all radiant (climate panels on top of the subfloor) with an indirect hot water maker. I had built a house a few years ago using the same system using a Buderus 115-34 boiler. She is very impressed with the comfort and efficiency of the system. With the Buderus GB 142 being available, what do you pros think would be the better choice for this system - a GB 142 using propane or a 115 series using oil.
