New air vents seemed to be clogged?
Dale
Dale Member Posts: 1,317
I would take the ones off that you suspect to be bad and blow into them to see if air comes through. If it does then fire up the system and see if steam comes out. Your inlet valve may be bad or alot of gunk in the rad.
  • johnw
    johnw Member Posts: 10
    I replaced all the air vents on the side of the radiators in my house yet two seemed to be clogged. They're not spewing anything but they do make a gurgle sound - almost like there is some water caught in there. I have the radiators pitched the right way so what's my next step?
