hot water radiator vent
digger
Member Posts: 13
I just completed installing a new boiler, converting a circa 1925 gravity system to a primary / secondary loop with four zones. my question is why were the air vents located 10" from the top of these old radiators?
Sounds like a steam rad?
TimJust a guy running some pipes.0 -
The original installation was gravity hot water.(obvious because of the pipe size and configuration. It was also equipped with a Honeywell heat generator). The radiators I refer to are the originals. The qulity of the original installation says a very skilled fitter did the work.Could he have used the wrong radiators? Are these ok for water? If so what's the trick to getting the air out? The seven originals,with low vent are cold on top. The five salvage rads with vents up high are toasty.0 -
Really sounds like steam rads. Is there a pipe across the top, or just the bottom. If the tops are cold, Steam they are. If there is a top pipe, you can tap & thread a vent in a plug or a top location, but if just a bottom pipe, you would need to tap each section. I have a rad I salvaged where it only had a bottom pipe, and someone tapped each section, and it heats great! Rads may have been replaced.
I have already tapped one and moved the vent to test a theory. It is now in the toasty column. I am still sure they are original. Lots of evidence. They are oversized for the application when you figure 180 degree water. With steam they would have rocked!0 -
If the whole rad heats with one vent, it must be a 2-pipe rad for steam or HW. If it was a steam rad, just the section you tapped would heat all the way up. the rest would still have air in them...usually about half way up.Just a guy running some pipes.0 -
You are wonderfully situated
to take advantage of outdoor reset with all of that cast iron bathing you in incredible heat. Tap for high vents as you have. Install TRV's on the radiators of you at all can.
If your boiler is a conventional cast iron one, primary-secondary with a 4-way mixing valve is a great way to achieve OD reset and superior savings and comfort.0 -
maybe they served as the expansion tank
maybe the original system had no expansion tank, but the tops of all the rads served the purpose...0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
