how to find old post on treating condesate water
mtfallsmikey
Member Posts: 765
Most make their own. Mfr's. used to have these as a kit. I believe Hot Rod posted a drawing on his.
Can some one tell me the secret to finding old posts under search? Tried using "treating condesate water", "lime chips", ect.
No luck. I know just a short time ago this was a thread with some good photo's. I need to build a device and can't find this post.
What am I doing wrong that I can't find this?
Thanks
Scott0 -
Try single words.
I searched for "limestone" and came up with this:
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=280872&_#Message2808720 -
Are you using
SEARCH on the Wall? You can't find Wall posts by using the Search box on the masthead. The Wall and the rest of the site are on two different servers.Retired and loving it.0 -
I used the search on the brown bar next to refresh not the search clear at the very top of the site. I will try one word and see what I get.
I think it was hotrod's drawing or someone had a photo on a previous post. Will check the past threads noted above.
Thank you,
As my grandmother used to tell me " Thanks, till you are better paid."0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
