Need small expansion tank
Timco
Timco Member Posts: 3,040
Sorry if I am missing something...but you are asking me or anyone here to go and buy you one and ship it? I can certainly get you one...just email me direct and include your payment method and address...Surely there is a local supplier in your area. Call plumbing supply houses and they will direct you to the nearest hydronics supplier for your area.
Tim
Just a guy running some pipes.
  • Mike C_3
    Mike C_3 Member Posts: 62
    I need to find a small tank. one gallon would be fine and some kind of wall bracket for it as well or a bracket for the 1.8 gal tank. or the 4 gal for that matter.
    Any help is appreciated!!
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    for what?
    Is this for a heating system or a domestic hot water piping application?
    To help you we need all the information. Chris
  • jim lockard
    jim lockard Member Posts: 1,059
    Information
    Starting with your credit card #. J.Lockard
  • Mike C_3
    HaHa
    I am a contractor doing radiant systems and need to find which manufacturer makes and sells them. I need a small hydronic tank. If you can give me a lead on one I can tell my suppliers
  • Timco
    Honeywell and Bell & Gosset are my favorites. If you re-read your orig post you will see how we were confused...
    Tim
  • Brad White_144
    Brad White_144 Member Posts: 17
    Watts
    makes a nice tiny one, about the size of a soccer ball, maybe two gallons? A #10 perhaps? Anyway, that is the one I use on a small electric DHWH for system flushing/heating and small radiant areas off-season. Cost me about $25 at a big box store. There, I said it.
  • brucewo1b
    brucewo1b Member Posts: 638
    Big Box Store
    have you no shame, and you dare show your face here ;-)
  • Timco
    It starts with a exp tank on a weekend, then some CI fittings, then you are hooked! "since I am here..."
    T
  • Brad White_144
    Exactly....
    Economy Plumbing and Heating Supply in Jamaica Plain, MA is my go-to supply house. They are not open on weekends so that left the one other place in town...
    But one has to agree, any time saved on the "convenience" at The Order of the Orange Apron is spent endlessly peeling barcode stickers off every fitting and nipple....
  • Timco
    Mapp gas burns those stickers right off!!!
    Tim
  • Brad White_144
    I have found a better way
    Hit the opposite side of the fitting with the torch for a second or two. It warms the fitting enough that the sticker peels right off.
    Too much heat though, and you weld the sticker permanently and have to complete the cremation.
    There is a place in hell for those who advocate barcode stickers on every foot of stock and fittings.... they sit under Lucifer's gaze peeling them off with bleeding fingernails for eternity... It is fitting. And just.
