Intake & Exhaust Vent Package
Jimbo_5
Member Posts: 222
Considering Lochovia knight or Trinity boiler but require an almost flush mounting on the outside wall, because it will be in the driveway between 2 houses. So I am looking for an Intake/Exhaust package that permits very close to the wall mounting. I have not seen such an option in their literature yet. Any suggestions?
Weil Mclain Ultra
Has a nice almost flush mounted termination kit.0 -
Thanks
Thank you, and I agree. In fact, I was ready to pick up an Ultra-80. But that very day I went to a local supply houses' show (ABCO), where I had a really good look at the Knight and Trinity--and the reps were really helpful. A few of the points they raised regarding the Ultra vs their product: Ultra has an aluminum HE, the others are Stainless. The electrical terminations for the Ultra are on the back side of the exhaust/intake. Yet, if I cannot locate a suitable exhaust/intake "fixture," I may go with the Ultra.0 -
Check your local codes:
Some areas restrict venting into walkway's especially when cars are parked in the vicinity. Exhaust may do damage to paint finish.
Mike T.0 -
Thanks, Mike
The car finish is not my problem. The driveway is just driven through, not parked in. But the 2 houses share the space between the houses, not the driveway. Besides that, having 2 elbow'd pieces of PVC dangling above the driveway would "look" awful. So I am trying to locate an almost flush mounted vent/intake to lessen the unpleasant look. The Ultra does offer one, Knight does not, and I am not sure about Trinity, but I will call them first thing in the morning. Honestly, I'd like to go with the Knight, mainly for the bells & whistles. We'll see.0 -
Jimbo
The Knight and most other modcons offer a concentric vent kit which hugs the wall - only 6" is exposed. Should be the solution as long as your vent is 3" or smaller. I understand that these vents are available in 4" but I've never seen one.
The only problem with these is that they take a lot of room inside the wall.0
- 167 Indoor-Air Quality
