inducer motor question
tim smith
Member Posts: 2,875
Some times they have the closing pressure or vacuum rating on them. Usually best to check with factory tech rep for rating if not on them. No generic #. GL Tim.
Is there a typical measurement in WC" for an inducer motor's draw? Will the pressure switch say what pressure in WC it needs? Seems this would be a quick & easy way to diagnose a bad inducer...I have a friend with a home for sale that has a condensing furn and the code says the switch opened 5 times durring a firing or the cond. pump is full, which I replaced...looked pretty nasty.
TimJust a guy running some pipes.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
