Honeywell M644A
Jack Rise
Member Posts: 3
Hope this helps:
Honeywell M644A
I'm looking for a schematic for a Honeywell M644A Modutrol head. Any ideas? Thanks0 -
Hope this helps.0 -
M644
These were reversing, two position motors (drive open, drive closed). Most were 24 volt, but there was one, the
M644B, that was 120 volt. If you can get the whole part number, I can get you the stroke & timing. Try the following website. http://hbctechlit.honeywell.com, and when you get on the site, type in M644 and you should find a spec sheet with wiring diagrams. These motors are obsolete, and have various replacements.0
- 167 Indoor-Air Quality
