Trane Flow Fittings
Jeff Lawrence_25
Member Posts: 746
And it had some 'Trane Flow fittings' on it. Those words were on one side and the number '2'was above '1977B' on the other, cast into the fitting. I am guessing that these were Trane's version of the monoflow tee's.
The picture below is a Wall-sized picture and the attachment is the same picture, only full size.
These pictures were taken in what is currently a basement bedroom. Supposedly, the former owner used this room as a home office. The piping was changed to out in the basement so it could be put on a separate circulator with it's own thermostat.
Are these monoflow fittings of Trane's design?
I think so, Jeff
they sure look like it to me.
The other fitting,
The one at the pump says 'Trane Lo City Ind' on one side and the other side says 'No.2 9358.' This on is right at the pump.
Thanks Doug.0 -
Thanks Frank
I think so too.
Have you ever seen any like this?0 -
Those are new to me
I'd say they date from the 1940s. Not sure where "Lo City, IND" is, nothing like that appears on my map. Looks like another quest for old Trane literature.
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
