Radiant ceiling
Steve L.
Member Posts: 35
Does anyone know where I can get some information on installing radiant heat in the ceiling? I have installed many floor systems over the years but none in the ceiling.
Thanks,
Steve L.
Thanks,
Steve L.
Check the manufacturers
Uponor and Rehau both have ceiling installation drawings and pictures in their installation manuals for the Quiktrak and Raupanel guides.
The ceiling installtions are really no different than an upside down floor staple-up system except you have to bond the tubing onto the back of the ceiling panel somehow. Many folks use the panel systems and then apply the drywall (sheetrock) to the panel face and there's your radiant ceiling. Don't forget the insulation on top to eliminate heat losses from the piping up to above.0
- 167 Indoor-Air Quality
