Wall mounted heat/a/c unit
Marty_9
Member Posts: 30
FEDDERS!
FEDDERS.COM
FEDDERS.COM
does anyone
know a manufacturer of an exterior wall mounted packaged heat & a/c unit. i saw one years ago. you mount it on the exterior wall and cut in a supply and return through the wall. usually for a 1 room application. thanks0 -
Bard Manufacturing (n/m)
thanks
- 167 Indoor-Air Quality
