Taco Mixing valve
maybe a silly question if you are asking here....pull the head off with an allen wrench and then you should be able to turn the temp knob up and down.....kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • BillHen
    BillHen Member Posts: 1
    Taco mix valve
    Have Series 5000 mixing valve, tried their website but couldn't get info on adjusting the valve to lower my mix temp. Using the valve for my radiant floor, (poured concrete). Any suggestions??
