tekmar 090
Scott90
Member Posts: 2
What about the moisture sensor and heater?
tekmar 090
Has anyone used a tekmar 090 moisture sensor with anything other than a tekmar controler?. If so did it work?0 -
Tekmar 90 sensor
The Tekmar 090 sensor operates on a 10 K ohm sensor so as long as the controller you are using with the sensor can be calibrated to accept a 10 K ohm signal it would work.
What kind of controller are you using it with.0
- 167 Indoor-Air Quality
