AntiFreeze Tank
SWS2
SWS2 Member Posts: 3
Have an oil / hot water system in a seasonal house. In the winter I drain house and turn the well pump off to prevent freeze up in a power outage. Does anyone know what type of a pressurized tank i can hook up to the boiler feed with with an antifreeze solution (already have antifreeze in heating system). I dont use well water in system anyway due to minerals. I was thinking of a bladder-type well tank, but really just need a 5-gallon plain tank i would fill, pressurize and monitor with gauges. Have low water cutoff for safety also.
  • Dave H_2
    Dave H_2 Member Posts: 622
    Glycol Pressure Tank
    Check these guys out.
    http://www.axiomind.com/
    Dave Holdorf
    Dave Holdorf
    Taco, Inc
  • steve gates
    steve gates Member Posts: 329
    make one
    here's what I do alot. From the line tee in order, isoation valve, feed valve, pressure gauge(0-100), boiler drain, #30 exp tank(sometimes larger).
    Dischare air from tank, fill tru boiler drain, repressurise tank to 100#.
    Sometimes in way off places I valve and union so client can bring to me for refill. Which as we all know shouldn't be very often after initial burping of system.
  • SWS2
    Thanks for replies. Any idea how much the axiom tank goes for, looks kind of expensive. I was leaning towrds making my own anyway. Think expansion tank with bladder is better than a pressurized holding tank only?
  • SWS2
    Thanks steve gates
    Thanks for info, purchased items today to make one. One question, how would you know if its empty. Pressure would lower a little, but not completely, correct?
