laundromat
Robert O'Connor_12
Member Posts: 728
I have 15 of these
http://www.metropolitanmachinery.com/natco.htm
in without any failure, the newest one is 12 years old. You can't kill these and they are perfect for the application.
Robert O'Connor/NJ
Robert O'Connor/NJ
laundromat
Looking to replace a boiler used for hot water at a laundromat. Besides a Munchkin VWH what other high eff. boiler could be used. My storage tanks are good and want to just replace the boiler. Boiler needs to be 199,000btu.
thanks0 -
Which Natco do u have?0 -
EVO
From Hamilton engineering is another brand. They are in detroit.0 -
evo
The Evo is a Munchkin VWH0 -
jeff
http://www.nationalcombustion.com/natco.htm
You're going to have to determine if this is what "you" need. In many cases this can be overkill so be sure of the load calculation before you order. Natco also handles equipment for smaller loads. The smallest application we had was 60 machines and each selection was slightly different.
Robert O'Connor/NJ
EVO
No it's not. The EVO hangs on the wall. The Munchkin sits on the floor. They use the same heat exchanger but that is where the simalarities end. These guys know laundromats.0 -
You are refering to the EVo DUo and Micro, they are wall hung. The EVO is a Munchkin, check out the link.
http://www.hamiltonengineering.com/evo99brochure1.html
All the products they sell are manufactured by someone else.
Most products they sell are made by lochnivar. I am not sure who is making the Duo for them.0 -
I like the Ao smith Cyclone.0 -
EVO/Munchkin
To clear things up- the EVO USED to be made by the same people that make Munchkin, but the Hamilton demands were different than what HTP needed, so they parted ways. The NEW EVO does use the Giannoni HX, and similar mechanical parts to it's predecessor, but the control aspect is different, among other things.0 -
So who is making the new Evo Duo/Micro for Hamilton?0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
