Another big Church job ( Ron Jr. )
Dale
Dale Member Posts: 1,317
Nice work as usual Ron, Is there a union in that header, I don't see one. Made your measurement to the drop at the equalizer really fussy. With the risers measurement that must have been a tough one.
  • This is a Lutheran Church in
    Port Washington , NY . This is phase 1 - replacing the steamer . There's a huge hot water boiler that'll be replaced right after this one's done .
    The old boiler was an American Radiator " Ideal " 6 section . Looks are deceiving - this was one big boiler , and an ugly mess inside . We had a real tight turn to hump these boilers out . Had to hand lift the sections up 2 steps to get them on the handtruck . For reference there's a pic of Kenny and Tom - Kenny's pretending to dead lift ( or do something else ) to the back section . Both of them are over 6 foot 3 .
    The last pic is the main pipes - I think that is a 6 by 2 1/2 by 2 1/2 cast iron tee . Tell me that tee can still be found . There is also a zone of hot water off the boiler .
    Anyone who's ripped out an old beasty like this knows there is no way to get the old stuff out without making a mess . We scraped up 3 buckets of rusty spooge . Spread some speedy dry on the floor and let it work it's magic . The floor looks pretty clean so far .
  • Day 2 - Burnham V904
    We reconnected both 2 1/2 inch steam mains to the header . No drop though , we ran into trouble in this town before .
    Kenny and Tony piped in the 3 returns while I played around with the zone off the coil and the float LWCO .
    All in all I think we are way ahead of schedule .
  • lchmb
    lchmb Member Posts: 2,997
    Now that
    Now that is how every install should be!! Incredibly neat, clean and easy to follow. I'd almost think you guy's have this to a science.... Good work my friend!!!! BTW, not willing to temp fate with a drop header? Come on now, how else will the inspector learn? LOL
  • Ron, that looks like
    an old Ideal Water Tube boiler. A monster if there ever was one.
    Technically, a drop header isn't needed with only one riser to the header unless you have a height issue. With two or more it greatly eases the job of putting the header together.
    Looks good so far!
  • ScottMP
    ScottMP Member Posts: 5,882
    I think it was Ron who
    learned a lesson : Don't try to teach an ignorant inpsector who's power hungry. Is'nt this where the inspector gave you a hard time because you installed an drop header and he had never seen on so " It had to be wrong " ?
    Nice work Ron and crew.
    Scott
  • Constantin
    Constantin Member Posts: 3,796
    Nice Job, Ron!
    Looks like the new beasty is about 1/3 the size of the old one... the header looks really nice and neat.
    What's going to run off the coil? The hot water system or a small zone?
    I'm a true believer that a drop header will separate water from steam better than no drop at all - and send the water back to the boiler . But we went full size 4 inch . The specs call for 3 inch minimum . It should be OK . Took a look today at the rads finally . It's a 2 pipe system and the 2 dry returns are the only place on the system for vents . I'm asking to thrown in Gortons .
    Thanks Frank .
  • The coil
    is running a fairly large baseboard zone . We set it up so we can flush all the muckety crap out without exposing the coil to it .
    This new one is really 1/3 the size . The hot water boiler will be 1/3 the size of the old one too .
    Thanks Constantin .
  • No union
    on the 4 inch . We build them to last ( God willing ) . We did leave plenty of room to cut the 4 inch riser and throw in a union if something needs to be redone .
    Once the 2 steam mains were tied in , connecting the equalizer and returns wasn't too bad . It helps to have plenty of every size 2 inch nipples . As a rough guess we shaved 1/2 a day of work compared to cutting and threading the nips .
    Thanks alot Dale .
  • We did
    convince the inspector that a drop header was beneficial to any steam boiler . I was real close to dropping it when we tightened the 4 inch ell . Another reason I decided not to drop it was the height of the boiler main - everyone woulda been walking into it , and space is tight on the right side .
    Thanks alot Scott .
  • Lchmb
    I ain't temptin nuthin' anymore . Not when 4 inch pipe is in play . I do wish manufacturers would include at least one diagram of a drop header with their manuals . We've seen a big dropoff of problem steam systems since we started doing it that way .
    Thanks buddy .
  • Your wish....
    Your wish shall be granted very shortly in the next printing of the Megasteam I&O Manual Ron. I was informed that we are in the process of putting together Dropped Header drawings for the next printing.
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
    U.S. Boiler Co., Inc.
  • Excellent
    Burnham is well known for having some of the most informational and well thought out install manuals , and this adds the icing to the cake .
    Thanks alot Glenn .
  • Day 4
    We got the steam up and running for weekend service . Had some trouble with the oil . We kept getting foam out of the oil de-aerator . Took a solid hour to track down the culprit - either an old 1 inch gate valve or the new Firomatic valve .
    We also skimmed and cleaned the returns for a few hours . The water was filthy .
    The V9 is a solid piece of iron . Real easy to draw together for a big boiler . And zero issues with the steam - I didn't hear a bang , not a ping , not even a whimper in the 2 or 3 hours we had it going .
    The 2nd pic is Kenny's returns . He was proud of 'em .
    Monday we start the hot water boiler in a different wing of the church .
  • aaron_4
    aaron_4 Member Posts: 42
    nice work
    Hello Ron,
    I wish this was the Matrix so I could just down load your boiler piping and do the same kind of work. Vary nice work I'll be posting a some pics of a boiler replacement soon and you can take a look.
    aaron
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Ron, as usual...
    you guys do top notch work...2 questions. Why the 3 vaporstats? And how is the tiger loop and oil filter suported...looks kind of like it could easily get bent over during a blow down. Also..FYI Tigerloop now has a combo unit that does the filter and deareator all-in-one....saves a lot of space and time...kpc
