vacuum in steam heat system?
Steamhead
Member Posts: 17,638
you probably have vacuum vents, which really only worked well with coal-fired boilers.
Is your system one-pipe or two-pipe? Are there vents on the radiators?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Consulting
Consulting
I have a vacuum created in the system, is this ok?
hi, I have a fairly modern boiler, I think, its a little over 10 years old, and recently rebuilt due to a cracked section. During normal operation the pressure gauge measures around 5psi, at points I've seen a slight vacuum, but never paid much attention. Yesterday we fired it up for the first time this season and I guess it was after it shut off that the gauge was pegged at 30 in Hg vacuum, this seemed a bit much, but what do I know? Any help or comments would be greatly appriciated. Thanks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
