heating unit blower won't shut off
joann_2
Member Posts: 2
Hello,
I live in a new condo development with garden style condos. Heat is propane gas. The heating unit in my condo is set at a 73 degrees. The blower has been constantly on for the past 24 hours, blowing air, but not hot air. I finally turned the heat off. Are we out of propane or is this some kind of energy saving thing? Should I call someone to look at the unit?
I appreciate the guidance. Joann
Joann,
Is the fan switch on the thermostat set for auto or on? Make sure its on "auto".
Have you changed the filter lately?
Tom0 -
Call someone. It is likely the safety circuit has a bad sensor somewhere in the loop. This causes the blower to just blow, with no heat. Could be a rollout sensor (some have a little reset button in the middle) and could be a high-limit sensor, which fails sometimes due to a dirty air filter.
TimJust a guy running some pipes.0 -
fan stuck on.
I would say probably 80% of the service calls we have w/ a problem like you state is a plugged air filter and furnace has tripped the high limit air temp to protect furnace. It may be a manual reset or a failed auto reset type. Good luck. Tim0 -
Joann
It''s always a good idea to have four Heating and A/C checked annually for safety and proper performance.
Mike T.0
- 167 Indoor-Air Quality
