Flare Fittings
Servicewiz_2
Servicewiz_2 Member Posts: 28
When flaring soft copper should you ream the pipe first? It has been my experience that when you ream the tubing , it gives you a rougher outer edge to the flare. Any help is greatly appreciated!
Servicewiz
  • Empire_2
    Empire_2 Member Posts: 2,340
    Yup
    They have a nice reamer on the market that eliminates the rough surface you are talking about. Using the wedge on your cutter just don't give you the finish you want. I think plumbing supply house carry these.
    Mike T.
  • Techman
    Techman Member Posts: 2,143
    Flare
    Evening All!Also,try your friendly refrigeration supply house .Enjoy!
  • bob_46
    bob_46 Member Posts: 813
    Wiz
    you might try a burnishing flaring tool. Parker-Hannifin(sp) makes a humdinger,Ridgid also.
  • Empire_2
    Yea Ridgid...
    That's the one I have. It's quick and evenly de-burs the pipe. I will never go back to any other tool.
    Mike T.
  • Big Ed
    Big Ed Member Posts: 1,117
    File then Ream
    After using a tubing cutter the end tends to taper in.You should file it down flat then ream.Dont take much filing,I use the file on my Leatherman since its always handy.....
  • Gene_3
    Gene_3 Member Posts: 289
    one of my cutters
    has a nice file on it, also if you go easy when cutting you'll find less of a ridge to ream or file, it only takes a few more seconds to slow down on the cut but can take a minute or more to clean it.
  • Pete Groenewold_2
    Pete Groenewold_2 Member Posts: 5
    I also have found that over-reaming soft copper will give you leaky flare joints. I have had good results using a pencil-type reamer (http://www.wheelerrex.com/images/p_images_largerview/tube_tools/920_Deburring_Tool.jpg) to lightly de-burr the cut end of the tube. Don't overdo it! A couple of revolutions should be plenty.
    Ditto on the Ridgid burnishing flaring tool. I've tried many others over the years, and I'm sold on this one.
