Steam boiler - Burnham, Weil McLain or Utica
Jim_101
Jim_101 Member Posts: 17
I am replacing an oil-fired steam boiler with another oil-fired steam boiler. I have spoken to a number of contractors and they all have their preferred boiler manufacture. Each of the contractors have said their preferred boiler is a Burnham or Weil McLain or Utica. No agreement on the best boiler among the contractors I have spoken with.
I would consider the Burnham MegaSteam, but the contractors don’t know seem to know that much about it because it is just released for sale.
I was wondering what you folks think is the best steam boiler for reliability, serviceability and durability? What would you recommend?
What is the reliability you folks have seen in the field with the elastomer seals Weil McLain uses to seal the connections between the boiler sections?
The connected load is 180 sq ft steam. The smallest boiler from all the manufactures looks over sized. The Weil McLain SGO-3 is oversized by the largest amount; it provides 354 sq ft steam. The Burnham V83 provides 283 sq ft steam and the Utica SFH-365s provides 246 sq ft steam.
What is the preferred method in this case to match the boiler to the connected load? Down fire the boiler or leave the firing rate alone?
I will not be using the boiler to provide domestic hot water.
Thank you for your advice.
