heating unit blower won't shut off
joann_2
joann_2 Member Posts: 2
Hello,
I live in a new condo development with garden style condos. Heat is propane gas. The heating unit in my condo is set at a 73 degrees. The blower has been constantly on for the past 24 hours, blowing air, but not hot air. I finally turned the heat off. Are we out of propane or is this some kind of energy saving thing? Should I call someone to look at the unit?
I appreciate the guidance. Joann
  • tom_49
    tom_49 Member Posts: 267
    Joann,
    Is the fan switch on the thermostat set for auto or on? Make sure its on "auto".
    Have you changed the filter lately?
    Tom
  • Timco
    Timco Member Posts: 3,040
    Call someone. It is likely the safety circuit has a bad sensor somewhere in the loop. This causes the blower to just blow, with no heat. Could be a rollout sensor (some have a little reset button in the middle) and could be a high-limit sensor, which fails sometimes due to a dirty air filter.
    Tim
    Just a guy running some pipes.
  • tim smith
    tim smith Member Posts: 2,886
    fan stuck on.
    I would say probably 80% of the service calls we have w/ a problem like you state is a plugged air filter and furnace has tripped the high limit air temp to protect furnace. It may be a manual reset or a failed auto reset type. Good luck. Tim
  • Empire_2
    Empire_2 Member Posts: 2,340
    Joann
    It''s always a good idea to have four Heating and A/C checked annually for safety and proper performance.
    Mike T.
