Home temp. monitor?
brucewo1b
brucewo1b Member Posts: 638
You might want to call your fuel supplier if you have propane or oil heat, many have the Scultel system available. The system monitors 3 things-oil/gas level in your tank, burner failure, and low temperature in your home. If any of these conditions occur, Scultel calls your oil/gas office and they can send someone out to take care of the problem. This system is ideal for those who are away at any time during the winter months. The system simply hooks into your home's phone jack. Have also conneced one of the leads to a float device in a basement to call for a flood condition.
  • RianS
    RianS Member Posts: 104
    Automated monitor
    Anyone know of an in home monitor for people who travel during the winter? I have a customer going to Arizona for the winter and wants a system that can call his son if the temp. drops below a set point. I have heard of then in the past, mainly used in well houses and other temp. sensitive areas. Any info would be great. Thanks Rian
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Sensaphone
    The cottage sitter by Sensaphone is exactly what you're looking for! Also has dry contact inputs available. Model 1100 if I recall correctly.
    Pete
  • RianS
    Sensaphone
    Thanks Pete, I will look it up on the web.
  • Cheap insurance...
    Just make sure they don't put any of your numbers in there...
    http://www.safemart.com/index.asp?PageAction=VIEWPROD&ProdID=6263
    ME
  • RianS
    Thanks
    Thanks for the info. I am sure he will be able to use one of these systems.
  • Todd_11
    Todd_11 Member Posts: 8
    freezalarms
    by Control Products, We have used them in several applications and they work well. Basic temp alarm,power outage, etc.
