hot air unit with Beckett burner
Mark_82
Member Posts: 11
When the burner starts--Should there be any smoke out the chimney-I see what most would say THATS NOTHING but it see a very little puff of smoke.. When i say very little--Its really minimal.. The burner in NEW and runs 100% clean--Even did a smoke test--runs 100%
Its almost like when the burner shuts down maybe there is some after drip--that burns off when the unit restarts..
This happens when the unit has been off for many hours...
Thanks for any help...
A Delay
This could be a delayed ignition or a bad nozzle causing after drip which ignites with a puff. If the burner is new have the tech come back it should be under warranty. There are tests and adjustments to check and possibley change. This condition is not acceptable and should not be let go.
Leo0
- 167 Indoor-Air Quality
