Wirsbo Thermostat Q?
singh
Member Posts: 866
I have an installed stat (wt-1) that won't go below 59*.
H.O. wants to lower when away for the week.
I know they can go down to 40*, is this one defective? or
could it be that this one goes into a ZCM has something to do with it.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I've noticed the latest batch
are that way. Seems the earlier versions went down to 41F. I'd like to see a low side of 41F for use in garages.
hot rod
New batch
The low temp limit on this new batch of Wirsbo t-stats can be adjusted. If I recall correctly, you open up the unit, and inside there's a little black button on the circuit board. Read instructions for specific procedure.0 -
Now I see..
the "special setting" button INSIDE the stat allows additional settings. It's on page 3 of the four page directions. I totally missed this page
If I read it correectly it should go down to 38F with a 2 degree differential?
I'll have to power one up and mess around
hot rod
Thanks
I will look for it!!
Now, why would you want to limit no less than 59* ? when 41* can provide freeze protection.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
