seen these radiators before?
ttekushan_3
ttekushan_3 Member Posts: 964
> I'd say that's what they are. <BR>
<BR>
Terry T
  • bobbyg_2
    bobbyg_2 Member Posts: 139
    Has anyone seen this style before? Before you say it. I know E.D.R. (Every Darn Radiator)-Dan' great book probably has it listed.
    Can I get the ratings from someone?
    I've bought 4-books myself (Radiant heating for the non-engineer, primary/secondary piping, pumpimg away, the golden rules of hydronic heating) and I'm trying to get my company to buy E.D.R. and one or two of his great books on steam......If I can't get them to do it....I will have to break down and get them.
    I owe everyone here (Dan H. and everyone who posts here) a thank you for all I have learned over the years. Big Thanks!
  • they
    They looks like old Weil Mclain radaint window unit..... Where's is this radaitor haven located? I hope it not loaded to be shipped to china!
  • bobbyg_2
    No this contractor was hired to cut the old boiler out and radiators. Another contractor is updating the system in this grand old house with central htg & a/c (bad choice in my opinion).
    He is storing them to use/sell. We are located in southwestern Indiana.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Yes,
    Retired and loving it.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Either the Raydiant or the Solray
    very nice units. Whoever is tearing them out is going to regret it when the fuel bills go up.
  • ttekushan_3
    Thanks...
    Its funny that this should come up now. I took a look at a job this spring and this is what I found as the garage radiator. Its the only one in the house like it. Took care of that vent issue. This rad really throws heat nicely.
    Over the weekend I was perusing photos and thought "Maybe I should post that for identification." Lo-and-behold this thread pops up! Its just like the others pictured, with the convector innards and radiant "outers."
    -Terry
    Terry T
    That one's rather rare
    it's the only one I've seen with no legs.
  • rob brown
    rob brown Member Posts: 69
    rads
    those are indeed wiel-mclain rads.very interesting that this thread pops up now because i just came across 5 that were ripped out of church we are working in. (thinking of installing as a one pipe steam system in my 1500 sq' cape). they are in dans e.d.r. book, but i think they were available in many configurations. yours appear to have full front and back radiant panels, as well as the "vectant". mine have front and back with no vectant. the book shows them with tin backs and single or double vectants,so getting a true edr may take some guesstamation.(unless somebody out there has old wiel-mclain rating tables and can help out?). glad to see i'm not the only one trying to save these beauties from the scrap yard. rob
  • ttekushan_3
    legs.
    Jeez. Another case of the obvious totally escaping me. Yup, its a legless model. I didn't think about it until now. Particularly unusual.
    Which brings me to the next question. The rest of the house has flush mount covers reminiscent of Arco/American standard fair. Except that the top openings are vertical, not horizontal. Some of these cover an Arco-like tube radiator, and others cover convectors. Were these kinds of items part of the W-M line? Or did the builder mix a bit...
    -Terry
    From the LIBRARY section:
    Terry T
    They were CI convectors
    some of the elements went bad and were replaced with small radiators inside the cabinets. I've had to do this from time to time.
  • found it!
    Went thru my late father's "desk system" and found the 1954 Weil Mclain Rayiant brocheres ( not as old as Dan H.) And have the ratings on single, dbl, and triple veacarts, interested? I'll make copies and send to you...
    If you could scan them
    save them as a PDF file and send it to Dan for the Library, that would be even better!
  • rob brown
    yes, i would be very grateful for that info. if you donate it to dans library, i'll just look there. thanks, rob
  • its coming
    Its coming ur way, Dan, since I don't have a desk puter or scanner, it'll arrives thru snail mails... Making copies of it now...
