conflicting thermastats
shawn_5
shawn_5 Member Posts: 52
yes the master bedroom thermostat is satisfing the master bathrooms thermostat when the radiant is supposed to be be calling.
  • chris_40
    chris_40 Member Posts: 12
    I have a issue with a thermastat I installed for radiant heat I used a honeywell t87 this is for a 2nd floor master bath what is happening is the master bedrooms baseboard heat is conflicting with the bathrooms heat is there anything I can do besides run a 5 wire thermastat and a floor sensor.
  • hvac64
    hvac64 Member Posts: 24
    shawn, how are ya? you dont really say whats wrong w/ the zone. is is coming up to temp? tom
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Try...
    turning the bedroom down to 60 degrees F and turning the bathroom up to 72 degrees F. Unless your clients are a rare exception, most people prefer a cooler sleeping environment anyway. At a minimum, you could put the bedroom on a programmable T-stat and leave teh bathroom hot all the time.
    ME
