Harman SF 260 & Van Wert PWC-4
I just had the Harman coal/wood boiler installed and tied in to the oil boiler. I can't get the upstairs radiators bled out and the pressure on the coal boiler is about 7 psi while the oil boiler is around 20 psi. Is there aanything I can check until I can get the plumber back to look at it ?
  • S Ebels
    S Ebels Member Posts: 2,322
    Can you...........
    Can you post a drawing or a picture of how they are tied together? Are you sure the gauges are correct?
