Tekmar 270
Jay_12
Jay_12 Member Posts: 46
Unfortunately, if you have a Munchkin that does not have the 925 control board, it cannot connect to the tekmar 270.
When using the tekmar 270 with a Munchkin with a 925 control board, a Munchkin Interface Adapter must be installed. This device is available from Heat Transfer Products.
Jay Vath
tekmar Control Systems
www.tekmarcontrols.com
  • Joe_55
    Joe_55 Member Posts: 62
    Tekmar 270
    I have an old Munchkin pre 925 I'm considering using a Tekmar 270 for ODR any thoughts on whether this will work. Does it intigrate with the munchkin? Thanks
