Gorton and Maid -O-Mist/Jacobus the Same?
bob young
Member Posts: 2,177
from what i was told gorton has a metal float but maid-o-mist is bi-metal no float.
Are Gorton and Maid-O-Mist the Same?
I've become a big fan of the Gorton radiator vents and I went online to order more and I found that Maid-O-Mist makes a model named Jacobus that looks the same and is described exactly the same as Gorton. See the link below. These are 50% cheaper than Gortons, sometimes more. Are they the same?
http://www.pexsupply.com/index.cfm/id_product/0f90e022-1d07-4f9b-8d4c-1f67dfc2c39b/action/product.show/category_header/10 -
i'm sure someone else will elaborate
but I believe the Maid-o-mist models have plastic components/floats on the inside vs. metal for Gorton.
-Michael0 -
gorton vs. jacobus
from what i was told gorton has a metal float but maid-o-mist is bi-metal no float.0 -
gorton vs. jacobus
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
