Steam insulation in NNJ?
...State Insulation in Perth Amboy (732)-442-5656.There address is 525 Johnstone street.
  • Todd_13
    Todd_13 Posts: 13
    Can't find steam insulation NNJ
    I've been to 4 local supply houses today and none of them have any 2" or 1 1/4" pipe insulation. Now I know why I never see any mains insulated after the asbestos is removed, no one carries it. Does anyone have a supplier in NNJ (Bergen, Essex, Passaic)?
  • clammy
    clammy Posts: 3,262
    in bergen
    toad in bergen county try henry's plumbing and heating supply (973)4277116 i get most of my insulation there if they don't have it they will order it for you .If you go there ask for paulie he knows where the good stuff is .If not i have in a pinch used foil faced duct wrap 2 inch with a good insulation staple gun it was cheaper then jm pipe insulation and works better then no insulation ,also there is another place i believe anderson supply in hackensack nj i believe it's on state street in south hackensack carries insulation another is white and shauger in paterson on straight st great bunch of guys there also peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • Todd_13
    Todd_13 Posts: 13
    Thanks
    Thank you for the numbers, I'll try them on Monday.
