Sizing boiler for oversized system piping w/ iron radiators
Unknown
Member
I'm drawing a blank on where to look up the percentage to add for various situations on hot water retrofit boilers with oversized mains.
I'd like to be able to confirm some things....
Noel
Noel
I'm looking for charts or guides published
Noel0 -
ask Dan
years ago i had a similar problem & the gents at wallace ennis helped me out.0 -
If you find, please share. Have looked deeply myself.
My best guess is to add nothing unless the basement or crawlspace has exceptionally high infiltration or exposure.
Heat loss calcs usually have the basement/crawlspace at a lower temp than actual. The heat liberated down there only reduces loss in the space above. No air pressurization problems with hydronics, so the situation tends to cancel itself out.0 -
Noel
Link doesn't seem to work. What's the section and title.
I need to revisit "The Library" MUCH has been added...0 -
older hot water heating systems
the third one down is an old I C S course from 1907.
Boiler sizing and derating for lower temperatures are in there. I'm still reading up on it.
Noel0 -
Perfect timing
This agrees with what I've been discovering this week.
Thanks, Dan. I really can use this info on a real situation this week.
http://www.pmengineer.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2732,161636,00.html
Noel0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 389 Solar
