bending 3/4\" copper type L
Patchogue Phil_28
Member Posts: 32
You can buy soft 3/4 copper coil. I think i's type-K?
bending 3/4\" copper type L tubing
I have a situation where it would be much easier if I just bent the tubing to accomodate a jog in the line of a hot water baseboard run in my home heating system.
Will this weaken the tubing to a dangerous level? Other problems?
Assuming that I use a tubing bender to assist me (tubing benders like I've seen at Home Depot), could I bend 3/4" copper (L or M) at a right angle?
Thanks
Jim
It is difficult to say what you may have seen,....
however,refridgeration 90's are a reasonable choise ...
swoopy bends can be made with bending tools .:)
i like swoopy's. if on the other hand you mean square about the closest way to roll is a street 90 or a "T' by run out and capped.0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
