Arco Aire Furnace Cooling Spec's
Bryan_16
Member Posts: 262
to be a 105K, with a 3-ton drive.
Arco Aire furnace Cool Spec
Does anyone have or know the CFM cooling spec for a Arco Aire low boy oil furnace model # OLR 105A12A ? Their site does not seem to have tech info.... Thanks for any info0 -
Here's a couple of links for you.
http://icpindexing.mqgroup.com/documents/003043/44531100807.pdf
This is a .pdf (Adobe Acrobat) file with the specs for the unit you listed.
http://www.arcoairedlr.com/pfindex.asp
This is the Dealer resources home page.0 -
Thanks
Thanks Glenn for the time and info.......0
- 167 Indoor-Air Quality
