switching relays(unconvential)
Marty
Member Posts: 109
If you are set on a plugin Graingers sells all sorts of stuff. another option may be a relay in a box most hvac distributors carry their basic spdt one a pilot one has enough capacity for a small pump
http://www.functionaldevices.com/
Hi:
I have a need for 12 switching relays that connect to circulators (007). I cannot use typical relays like SR506's
The output from my zone manager will have 24volts to control the circ's. I priced relays at my electrical wholesaler the relay, plug-in-base, mounting channel and
cabinet cost seemed high, $500.00 and I would have to assemble. I looked at relays on-line and it is boggling
some had lights oooh! Anyone done this or maybe a supplier you know? I didnt like the honeywell's I like a plug in type.
Thank's
Rich P.0 -
been there,
look at 'other" electrical places. i.e. electronic stores. (wholesale) Johnstone supply, comes to mind. Here in Utah i got the relays I wanted from Standard Electronics supply, but that was years ago. The relays you want are out there, in your area. It is a case of finding them.0 -
did you look at
ARGO ARM series?0 -
ice cube relays?
should be available at most electrical suppliers. Johnstone and graingers have plenty.
Watch out when you shop electrical suppliers, they often stock 24V dc coils. Not all counter help realizes the difference
hot rod
relays
Been there done that! trust me on this one these little babys are the best thing to have around. dependable relay in its own little enclosure..... http://www.functionaldevices.com/ChartPilot.html0 -
**** Cheney installs
and sells this brand at www.ultra-fin.com. I've not priced them, but they look neat and simple.
hot rod
Johnstone supply
sells an RIB relay, self enclosed e.m.t. connector that works well, spst,spdt,dpdt even has a LED light to show when it's been made. 24v/120v-2 or 3 h.p.0 -
thanks
Thank you all for your help I will look those things up!!
Rich P.0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
