Pictures when searching
Glenn Harrison_2
Member Posts: 845
go to the post you were looking for, and then click on "Show Thread" and the enire thread will pop up, then scroll down to the post and the links for the pics should be under attachments for the appropriate post.
Pictures using search
When you are using the search feature on the wall to check out old posts, is there a way to view the posted photo's as well. I can't see any photos attached. Also is "search" the easiest way view old posts??0
- 167 Indoor-Air Quality
