Need help!!
DanHolohan
Member, Moderator, Administrator Posts: 16,674
The one with the double coil.
Retired and loving it.
This piped object is on a steam system, with the steam header connected to the left side. What is this?0 -
Excelso
made indirect heaters.Retired and loving it.0 -
steam trap
Looks like a float & thermostat steam trap. very strange f. & m. hangers though.at first it looked like 1/2 " lines were connected to 2 " piping. gotta be a trap0 -
Excelso
didn't make traps.Retired and loving it.0 -
trap or coil --looking good
maybe the guy that installed it could not get a trap and installed a coil instead , collected his cash and called it a day. the hangers alone are worth at least a thousand. not every dead steamfitter was a genius. i have seen more than a few puzzlers in n.y.c.0 -
That's the same one
pictured in the "what is it?" thread. Since the return connection (seen above dirt leg) is plugged, it's safe to assume this hasn't worked in years.
It was probably used to heat water in an overhead tank by gravity.All Steamed Up, Inc.
Consulting0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
